[OpenLayers-Dev] Cluster strategy activation
Tim Schaub
tschaub at opengeo.org
Thu May 20 17:46:59 EDT 2010
strk wrote:
> On Thu, May 20, 2010 at 09:54:50AM +0200, strk wrote:
>> Hi there,
>> I noticed that the Cluster strategy activation does nothing
>> clustering only happens when you add features _after_ the control is
>> activated.
>> Sound reasonable, but the strategy can't be activated until the layer
>> is placed on the map, so this makes it impossible to have a workflow like
>> this:
>> 1. Create layer with cluster strategy
>> 2. Add features to layer
>> 3. Add layer to the map (triggers activation)
>> Does it make sense for the Cluster.activate to instead perform
>> the initial clustering when the layer already contains feature ?
So what does `strategy.activate(); strategy.deactivate();
strategy.activate()` do?
If activate clusters, then does deactivate uncluster?
I haven't checked out the attached diff, but these are immediate
questions that come to mind. Drop a link to a ticket if you've opened one.
Thanks,
Tim
> Attached is a patch doing that, for review.
> It's not on trac cause I dont not remember the account password
> and can't find a "remind me" button on http://trac.openlayers.org/register.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
