[OpenLayers-Dev] Re: lib evaluation performance
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Nov 2 10:47:29 EDT 2010
Eric Lemoine-2-2 wrote:
> Hi
> To follow up on <http://trac.osgeo.org/openlayers/ticket/2899> I've
> run experiments ...
> This change cannot be done in 2.x as it will break
> application code defining classes using OpenLayers.Class...
> Thanks,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
And more... 2.x code can be compatible with pure JavaScript. It is only
necessary:
var A = function () {...} / / constructor
A.prototype = {
    initialize: function () { // * Deprecated *
        A.apply(this, arguments);
}, / / Prototype definition
View this message in context: http://osgeo-org.1803224.n2.nabble.com/lib-evaluation-performance-tp5696447p5697727.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
