[OpenLayers-Dev] Re: lib evaluation performance
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Nov 3 11:51:18 EDT 2010
> Hi Eric Lemoine,
> For other reasons I am also testing the performance of the initialization.
> To stabilize a little the sample, I remove the extraneous peaks with this
> code:
> function showAvg(testName,times) {
> function staValues(t) {
> var s = 0, v=0;
> for(var i=0, l=t.length; i<l; i++) {
> s += t[i];
> v += t[i]*t[i];
> var ev ={};
> ev.avg = (s/l);
> // Normalized standard deviation
> ev.nsd = Math.sqrt((v/l)-(ev.avg*ev.avg))/ev.avg;
> ev.l = l;
> return ev;
> var t = times.slice(0);
> t = t.sort(function (a,b){return a - b;}); // sort ascending
> var ev;
> while (true) {
> ev = staValues(t);
> if (ev.avg == 0 || // break if all values are 0
> ev.nsd <= 0.5 || // clean up of the normalized
> standard deviation is less than 0.5
> ev.l <= times.length * 2/3 // remove 1/3 of the sample
> maximum.
> break;
> console.log(testName+";", ev.avg.toFixed(1), "; max;",
> t[ev.l-1], "; nsd;", ev.nsd.toFixed(3), "; sample;", ev.l); // to monitor
> cleaning
> t.pop(); // remove the anomalous peak produced by the
> garbage collect or other
> t.shift(); // remove the minimum to balance the sample
> console.log(testName+":", ev.avg.toFixed(1));
> used by:
> showAvg("Old-style class",timesArray);
Nice. I'm happy to see new experiment results.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
