[OpenLayers-Dev] Layers overlapping
Andreas Hocevar
ahocevar at opengeo.org
Wed Nov 17 04:51:15 EST 2010
are you using a SelectFeature control on the polygon layer? Or are you parsing the GeoJSON manually instead of using OpenLayers.Layer.GeoJSON or OpenLayers.Layer.Vector with a WFS or HTTP protocol?
Regards,
Andreas.
On Nov 17, 2010, at 10:32 , Denis Rykov wrote:
> I try to add on my map two vector layers from GeoJSON files. One of the layers - polygonal, another - points. But point layer is always overlapped by polygonal layer. I use different combinations of addLayer method, try to change z-indexes of layers, use raiseLayer method - no results.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
