[OpenLayers-Dev] Re: OpenLayers.Popup.FramedCloud rendering problem
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Sat Nov 20 11:59:46 EST 2010
Yes, There is a bug in the positioning of "Popup.FramedCloud" when an anchor
is used, but is due to a bug in "Popup.Anchored"
The bug can be corrected by changing two lines of code in "Popup.Anchored":
Index: lib/OpenLayers/Popup/Anchored.js
--- lib/OpenLayers/Popup/Anchored.js (revisión: 10904)
+++ lib/OpenLayers/Popup/Anchored.js ()
@@ -186,10 +186,10 @@
var size = this.size || this.contentSize;
var top = (this.relativePosition.charAt(0) == 't');
- newPx.y += (top) ? -(size.h + this.anchor.size.h) :
this.anchor.size.h;
+ newPx.y += (top) ? - size.h : this.anchor.size.h;
var left = (this.relativePosition.charAt(1) == 'l');
- newPx.x += (left) ? -(size.w + this.anchor.size.w) :
this.anchor.size.w;
+ newPx.x += (left) ? - size.w : this.anchor.size.w;
return newPx;
This is not yet a solution accepted by OpenLayers, I opened a ticket
http://trac.osgeo.org/openlayers/ticket/2870 #2870 to solve the problems
but nobody has yet reviewed.
There is also a small problem on the border for which I have not written
solution, see http://trac.osgeo.org/openlayers/ticket/2939 #2939 .
Regards,
Xavier
Kiks wrote:
> Hi,
> I've noticed that with the OL 2.10 release the
> OpenLayers.Popup.FramedCloud has a rendering problem that doesn't show
> correctly the "cloud".
> Anyone else has this little problem?
> Kiks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Popup-FramedCloud-rendering-problem-tp5530749p5758474.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
