[OpenLayers-Dev] GeoWebCache layer
Schuyler Erle
schuyler at nocat.net
Mon Nov 22 17:47:06 EST 2010
Iván, this looks pretty cool. Is there any reason not to rename the layer to OpenLayers.Layer.GeoWebCache? I'd recommend doing so, and then filing a ticket in Trac for inclusion in OpenLayers.
SDE
On Nov 22, 2010, at 2:39 PM, Iván Sánchez Ortega wrote:
> Hi all,
> I'm working in a project that involves running GeoServer+GeoWebCache to
> generate a whole bunch of tiles, then copying all the unmodified cached tiles
> to a frontend., then put openlayers on top.
> The trick is that GWC's way of naming cached tiles looks like this:
> EPSG_$projection_$namespace_$layer_08/05_04/0161_0146.png
> Here, 08 is z, 0161 is x, and 0146 is y. But the zero-padding and that
> mid-level directory prevents us from using XYZ or TMS.
> Worry no more! The brand-new GWC layer allows to load a mirrored copy of GWC's
> tile cache with no hassle, even accounting for GWC's bugs! Looky here:
> http://ivan.sanchezortega.es/GWC.js
> Usage is pretty straightforward:
> var gwc = new OpenLayers.Layer.GWC({});
> gwc.url = "path_to_cache_dir/EPSG_12345_namespace_layer_";
> gwc.type = 'png';
> gwc.name = "foobar"
> map.addLayer(gwc);
> Best,
> Iván Sánchez Ortega <ivan at sanchezortega.es> <ivan at geonerd.org>
> Proudly running Debian Linux with 2.6.35-trunk-amd64 kernel, KDE 3.5.10, and
> PHP 5.3.3-4 generating this signature.
> Uptime: 23:28:21 up 22 days, 10:10, 6 users, load average: 2.38, 2.04, 1.47
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
