[OpenLayers-Dev] Kinetic Dragging
Eric Lemoine eric.lemoine at camptocamp.com
Tue Nov 23 12:27:02 EST 2010
On Tue, Nov 23, 2010 at 11:51 AM, Gregers Gram Rygg
<gregersrygg at gmail.com> wrote:
> Great work Eric,
> Nathan Vander Wilt did something similar in May
> (http://lists.osgeo.org/pipermail/openlayers-dev/2010-May/006013.html).
> Also with awesome smooth multi-touch zooming. He didn't have time to
> split the code into separate patches, but he has put the code on
> GitHub: https://github.com/andyet/OpenLayers-Multitouch
> I really want to get this into OpenLayers, but haven't had time to
> look at it yet.
> Nathan's approach is a bit different, but just want to inform you about it.
Thanks everyone for your feedback. And thank you Gregers for letting
me know about Nathan's work, I has missed it. In my code the kinetic
code is a separate file, this is to avoid increasing the library size
if kinetric dragging isn't wanted in the application. Also, my code
reuses the Tween.js code for animating the map movement resulting from
the momentum. Right now, I'm busy on other stuff, but I hope to find
time (or budget) to complete this work. Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev mailing list
