[OpenLayers-Dev] Prevent adding a point to a sketch
geographika geographika at gmail.com
Fri Oct 1 04:13:33 EDT 2010
I want to be able to prevent a user from adding a new vertex to a line
sketch tool if I determine the location is invalid.
So for example in http://openlayers.org/dev/examples/editingtoolbar.html
I may want to prevent a user from clicking on the sea (the code to work
out if a point is valid or not is fine).
My draw feature tool calls a pointHandler function correctly, but there
seems no way to cancel the addition of a new point.
var myControl = OpenLayers.Control.DrawFeature(myLayer,
OpenLayers.Handler.Path, {
                     callbacks: {
                         point: pointHandler
     function pointHandler = function(newPoint){
         if(!_isValidPoint){
             //none of the following work...
             //myControl.handler.destroyFeature();
             //myControl.removePoint();
             //newPoint= null;
Looking at the source code for at
http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js,
the callback occurs after the new geometry is added but before it is drawn.
127
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L127>
	        this.line.geometry.addComponent(
128
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L128>
	            this.point.geometry, this.line.geometry.components.length
129
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L129>
130
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L130>
	        this.callback("point", [this.point.geometry, this.getGeometry()]);
131
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L131>
	        this.callback("modify", [this.point.geometry, this.getSketch()]);
132
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Handler/Path.js#L132>
	        this.drawFeature();
I also tried a custom OpenLayers.Control.Click with stopSingle set to
true, but new points are added on the "mousedown" event, and so the
click control is called afterwards.
Are there any ways to achieve this, or will it involve overriding
browser events?
Apologies if this is in the wrong mailing list.
Thanks for any help,
Seth G.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20101001/75efc01c/attachment.html
More information about the Dev mailing list
