[OpenLayers-Dev] Re: Reduce OpenLayers.Layer.Grid's buffer throughout
Matt Priour mpriour at kestrelcomputer.com
Fri Oct 8 22:06:30 EDT 2010
This will work but should be done AFTER you instantiate all your layers.
Otherwise, the defaults specified in the class will overwrite the prototype
value. When you do it after the instantiation then it will change all
instances of OpenLayers.Layer.Grid and all its subclasses.
Matt Priour
Marc Jansen-2 wrote:
> Hi jtm,
> try to add
> OpenLayers.Layer.Grid.prototype.buffer = 1;
> to your script.
> This is untested.
> Regards,
> Marc
> Am 07.10.2010 23:23, schrieb joanne.mcgraw at sympatico.ca:
>> I can't believe this is a question that no one has any ideas about.
>> It's more likely that I'm not posting these into the forum properly. I
>> seem to be the only person who has viewed my post (actually 2 posts
>> because I really did mess up the first time and posted a second time,
>> which may have been a mistake...who knows).
>> Anyway, I'm trying a different approach this time and mailing directly
>> to 'dev at openlayers.org' rather than using the forum GUI. Could someone
>> just Reply All once and let me know if these are getting out there at
>> all?
>> Cheers
>> jtm
>> > Date: Wed, 6 Oct 2010 16:32:28 -0700
>> > From: joanne.mcgraw at sympatico.ca
>> > To: dev at openlayers.org
>> > CC:
>> > Subject: [OpenLayers-Dev] Reduce OpenLayers.Layer.Grid's buffer
>> throughout
>> > I've seen the posts that show me how to reduce the buffer size to 1
>> when I am
>> > adding an individual layer to my map. E.g. new
>> OpenLayers.Layer.WMS(...,
>> > {buffer: 1});
>> > Is there a way to change it for all of OpenLayers?
>> > I've tried:
>> > OpenLayers.Layer.Grid = OpenLayers.Class(OpenLayers.Layer.Grid, {
>> > buffer: 1
>> > And, although the prototype says buffer = 1 when the new object is
>> being
>> > initialized, in all the functions for the OpenLayers.Layer.Grid
>> object the
>> > original buffer value of 2 is referenced through 'this'.
>> > Obviously, I'm doing this wrong.
>> > Any ideas what the correct way to approach this is?
>> > View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Reduce-OpenLayers-Layer-Grid-s-buffer-throughout-tp5609405p5609405.html
>> > Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> > _______________________________________________
>> > Dev mailing list
>> > Dev at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Dev mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Reduce-OpenLayers-Layer-Grid-s-buffer-throughout-tp5609405p5617129.html
More information about the Dev mailing list
