[OpenLayers-Dev] Working on 3.0 git...
Alexandre Dube
adube at mapgears.com
Tue Oct 12 15:23:27 EDT 2010
Eric,
Yep, that helped a lot. Both pull requests are send too.
Thanks,
Alexandre
On 10-10-12 02:44 PM, Eric Lemoine wrote:
> On Tue, Oct 12, 2010 at 8:02 PM, Alexandre Dube<adube at mapgears.com> wrote:
>> Hi devs,
> Hi
> I'm not a github expert, but I'll try to answer your questions, hoping
> that others will correct my mistakes.
>> I started working on 3.0 tickets and got used with git for the first time.
>> I have a couple of questions I'd like to ask, but first a small overview of
>> the situation : so far, I adopted a "one branch per ticket" strategy. So
>> far, I did two (#522 and #1275) , i.e. I commited to my fork the fixes
>> needed for each one in their specific branch. I was able to get the master
>> "upstream" repo to update mine as well.
>> === what should I do now ? ===
>> Now, I'm just wondering what I should do with the work I did. Should I
>> leave a note on the trac ticket even though it's not to be commited in svn ?
>> Should I do nothing since the graph already demonstrate pretty much every
>> work done by everyone ?
> Let's say you're done with #1275. You can merge your "1275" branch
> into your master, and push this to your origin's master (your github
> repo). Once done you can do a pull request, for a core developer to
> pull your commits in the master of openlayers/openlayers.
>> === where is my 522 branch ? ===
>> About the github network graph [1], I don't see yet the last branch with
>> its commit I just did. Is there supposed to be any delay ?
> Maybe the branch exists in your local repository but not in your
> github repository. To create the branch in your github repository I
> think you can just push your commits to this branch as it existed:
> $ git push origin 522:522
> Hope it helps,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
