[OpenLayers-Dev] Re: Bug in the positioning of popups "Anchored",
"Framed" and "FramedCloud" using argument "anchor".
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Fri Oct 15 02:27:25 EDT 2010
Hi Roald,
Ok, I watch the "popupMatrixVector.html" I need a little time.
I was concerned it seemed that no one saw the problem, thanks.
Xavier
Roald de Wit-3 wrote:
> Hi Xavier,
> It looks like I'm responsible for that one... My apologies for causing
> problems. I have to admit that I did not test these changes with
> OpenLayers.Layer.Markers but with OpenLayers.Layer.Vector.
> After having looked into the issue, I think (and hope) that we can keep
> the changes in that revision and, if possible, fix the issue for markers.
> Some arguments against reverting the change:
> - It does indeed fix a problem where a popup related to a vector feature
> did not use the anchor as it should
> - Markers are sort of 'not done'. Rule is to use vectors. (see [1] for
> example)
> - createPopup is not an API property (not sure if that was intentional)
> I rewrote popupMatrix.html to work pretty much the same but then for
> vector layers (attached to the #2870). Maybe it's a good idea to replace
> the old one with this one (provided that it's bug-free)?
> Please let me know if this solves the issue for you. If not, I'm sure it
> should not be too hard to make it work for both Vector and Marker
> features and I'm happy to investigate that.
> Regards, Roald
> [1]
> http://osgeo-org.1803224.n2.nabble.com/Markers-vs-Features-td1828248.html
> On 11/10/10 19:25, Xavier Mamano (jorix) wrote:
>> see http://trac.osgeo.org/openlayers/ticket/2870
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-in-the-positioning-of-popups-Anchored-Framed-and-FramedCloud-using-argument-anchor-tp5621326p5637829.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
