[OpenLayers-Dev] Patch to Panel.js
Bart van den Eijnden bartvde at osgis.nl
Fri Oct 15 15:30:26 EDT 2010
this has been fixed already, see:
http://trac.osgeo.org/openlayers/ticket/2855
Thanks for the report anyway!
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Oct 15, 2010, at 8:59 PM, Matthew Michels wrote:
> I haven't gotten around to subscribing to the Trac system yet for OpenLayers.
> Will try to do that soon.
> We found what appears to be a bug in Panel.js, namely that 'children' appears
> to not exist on older (3.0 and earlier) versions of Firefox.  I believe that
> 'childNodes' is the correct W3C member.
> We made this change to fix the problem:
> --- OpenLayers-2.10/lib/OpenLayers/Control/Panel.js	2010-10-12 00:18:35 UTC (rev 15870)
> +++ OpenLayers-2.10/lib/OpenLayers/Control/Panel.js	2010-10-12 01:53:25 UTC (rev 15871)
> @@ -165,9 +165,9 @@
>      * Method: redraw
>     redraw: function() {
> -        if (this.div.children.length>0) {
> -            for (var l=this.div.children.length, i=l-1 ; i>=0 ; i--) {
> -                this.div.removeChild(this.div.children[i]);
> +        if (this.div.childNodes.length>0) {
> +            for (var l=this.div.childNodes.length, i=l-1 ; i>=0 ; i--) {
> +                this.div.removeChild(this.div.childNodes[i]);
>         this.div.innerHTML = "";
> We wanted to report this in case this could be of help to others.
> Thanks,
>  Matthew
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
