[OpenLayers-Dev] WFS GetFeature with Filter: bug?
Christoph Baudson
christoph.baudson at wheregroup.com
Wed Oct 20 11:13:48 EDT 2010
Andreas Hocevar wrote:
> Hi,
> how did you create your GetFeature request?
(Moved to GeoExt-Dev, seems to be an issue with GeoExt FormPanel)
Thanks Andreas
> Regards,
> Andreas.
> On Oct 20, 2010, at 16:18 , Christoph Baudson wrote:
>> Hi OpenLayers devs,
>> when creating a WFS GetFeature request with OpenLayers 2.10 I get this [1].
>> However, MapServer doesn't interpret the filter, all features of the featuretype are returned. Apparently, this is due to the "And" operator wrapping only a single term. The OGC spec says, "And" shall only be applied with two or more terms.
>> Is this a bug in OpenLayers? If I remove the "And" tags from the XML, it works in MapServer.
>> Your help is very much appreciated,
>> Christoph
>> [1] http://osgeo.pastebin.com/qgU4pJ9R
>> Where2B Konferenz 2010
>> 09. Dezember 2010 in Bonn
>> www.where2b-conference.com
>> Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> _______________________________________
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Dev
