[OpenLayers-Dev] building openlayers in eclipse
x_tls_x at die-optimisten.net
Fri Oct 22 02:38:56 EDT 2010
Hi friend,
thanks for mailing it. But how can i use these files with python 3 to built own open layers projects? I need some auto completition in eclipse for my java script-projects using open layers.
Thanks for your help,
x_tls_x
2010/10/21 Kris Geusebroek <kgeusebroek at xebia.com>:
> HI James
> Attached you will find the patch files for the build and tools directory to
> be able to build openlayers with python3
> I recreated them so there might be some changes i missed. Let me know if
> this works for you
> Cheers Kris
Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
More information about the Dev
