[OpenLayers-Dev] building openlayers in eclipse
x_tls_x at die-optimisten.net
Fri Oct 22 09:00:14 EDT 2010
sry it doesnt work. I set the patch with team->apply patch. I 've installed the phyton plugin. Something missing?
thxs a lot,
x_tls_x
2010/10/22 Kris Geusebroek <kgeusebroek at xebia.com>:
> Hi James you need to apply these patches with the apply patch functionality of eclipse. If you can't get it to work I will send you the compete files tonight.
> Cheers kris
> Op 22 okt. 2010 om 08:38 heeft "x_tls_x at die-optimisten.net" <x_tls_x at die-optimisten.net> het volgende geschreven:
>> Hi friend,
>> thanks for mailing it. But how can i use these files with python 3 to built own open layers projects? I need some auto completition in eclipse for my java script-projects using open layers.
>> Thanks for your help,
>> x_tls_x
>> 2010/10/21 Kris Geusebroek <kgeusebroek at xebia.com>:
>>> HI James
>>> Attached you will find the patch files for the build and tools directory to
>>> be able to build openlayers with python3
>>> I recreated them so there might be some changes i missed. Let me know if
>>> this works for you
>>> Cheers Kris
>> Neu: GMX De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
>> Jetzt De-Mail-Adresse reservieren: http://portal.gmx.net/de/go/demail
More information about the Dev
