[OpenLayers-Dev] proxt.cgi
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Oct 22 21:02:08 EDT 2010
On Oct 22, 2010, at 5:48 PM, ext Tim Schaub wrote:
> On 10/22/10 1:38 PM, Mohammed Rashad wrote:
>> error running proxy.cgi
>> http://localhost/cgi-bin/proxy.cgi?url=http%3A%2F%2Fdemo.opengeo.org%2Fgeoserver%2Fwfs
>> Some unexpected error occurred. Error text was:<urlopen error [Errno 111] Connection refused>
> If you are using the proxy.cgi file from our examples directory, make
> sure that demo.opengeo.org is listed in the "allowedHosts" list.
This error message will not be returned if this is the case. Typically
this error message is caused as a result of an overzealous firewall
on the machine in question.
-- Chris
> If it is listed, make sure your machine can resolve the URL and get a
> response from it:
>     curl http://demo.opengeo.org/
>> Does anyone seen this error before. If yes please help me. I am stuck
>> with work
>> Rashad
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
More information about the Dev mailing list
