[OpenLayers-Dev] Format.XML, xmlns and QName
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Sep 2 05:31:29 EDT 2010
Hi list,
I've been tracking down a problem in the SOS client, where the XML created
had a value which is QName, i.e.:
<resultModel>om:Measurement</resultModel>
However, even though "om" is in the namespaces object of the format,
xmlns:om was not added automatically.
Is there a way to do this, similar to what is done for elements which are
a QName, where things go okay automatically?
I now programmatically added the xmlns as a workaround.
Index: lib/OpenLayers/Format/SOSGetObservation.js
--- lib/OpenLayers/Format/SOSGetObservation.js (revision 10712)
+++ lib/OpenLayers/Format/SOSGetObservation.js (working copy)
@@ -104,6 +104,7 @@
write: function(options) {
var node = this.writeNode("sos:GetObservation", options);
+ node.setAttribute("xmlns:om", this.namespaces.om);
this.setAttributeNS(
node, this.namespaces.xsi,
"xsi:schemaLocation", this.schemaLocation
Best regards,
Bart
More information about the Dev
