[OpenLayers-Dev] Re: strange behaviour on google-bing map switching
crb
jcbeaude at yahoo.com
Fri Sep 10 18:43:52 EDT 2010
I've seen similar behaviour: I have Bing, GMaps and ESRI cached layers all
in the same map. Switching to GMaps and ESRI works fine, but when switching
to Bing the map zooms in one level w/o touching any controls. What's more,
if there's a vector layer on top of it, the vector layer (correctly) doesn't
zoom, but then they're overlaid inaccurately over the Bing layer. Also
noticed (w/ Bing layer only) that when opening a popup that causes the map
to pan, the Bing layer "wiggles" for a couple of seconds after the pan.
Anyone know why this might be the case and/or whether 2.10 is going to fix
it?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/strange-behaviour-on-google-bing-map-switching-tp5134656p5520198.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
