[OpenLayers-Dev] The domain for sale "freemap.in" is used in 5
examples.
christopher.schmidt at nokia.com
Mon Sep 13 07:05:55 EDT 2010
On Sep 12, 2010, at 11:37 AM, ext Xavier Mamano (jorix) wrote:
> Hi,
> The domain for sale "http://freemap.in/" is used in the following examples:
> "getfeatureinfo.html", "google-reproject.html", "gutter.html",
> "projected-map.html" and "spherical-mercator.html"
Good point. Thanks.
I don't have a server available that is a good demonstration of:
1. Using a differently projected (not 4326 or 900913) map
2. A map which is affected significantly by gutters
3. A good GetFeatureInfo example.
Does anyone have any suggestions/offers of what to use for these
examples?
I would assume that the third would be easy to set up against one
of OpenGeo's demo servers; perhaps tschaub or ahocevar can comment
on that.
The google-reproject.html example should just go away, and removing
the freemap.in layer from the Spherical Mercator example probably
doesn't hurt either.
-- Chris
More information about the Dev
