[OpenLayers-Dev] Question: Vector layer with draw & modify feature
Alexandre Dube
adube at mapgears.com
Thu Sep 16 08:17:51 EDT 2010
Hi Moiz,
BTW, this thread would have been more suitable for the "users"
mailing list.
Take a look at the "TransformFeature" control [1]. It might just be
the right tool for you.
Regards,
Alexandre
[1] http://www.openlayers.org/dev/examples/transform-feature.html
On 10-09-15 03:11 PM, Moiz Bhukhiya wrote:
> Thank you so much Alexandre for your response. You are absolutely
> right, it is working now as it should. But I have one more question.
> Is there a way to resize it from all four corners, I don't need to
> keep the aspect ratio. I would like to resize the box like a cropping
> tool( http://odyniec.net/projects/imgareaselect/ ). I am also having
> another problem. When I assign {displayClass:
> "olControlDrawFeaturePoint"} to modifyFeature, it doesn't give
> strictly horizontally aligned rectangles. I can draw rectangles in
> that case but they form an angle.
> I'd really appreciate any of your help.
> Thanks,
> Moiz
> On Wed, Sep 15, 2010 at 7:24 AM, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> Hi Moiz,
> The constructor of the control only takes 2 parameters [1] and
> you give it 3. This might be why it doesn't work.
> Regards,
> Alexandre
> [1]
> http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers/Control/ModifyFeature-js.html#OpenLayers.Control.ModifyFeature.OpenLayers.Control.ModifyFeature
> On 10-09-15 05:32 AM, Moiz Bhukhiya wrote:
>> Hi,
>> I am using vector (polygon) layer with draw feature and modify
>> feature. Let me explain first what I am trying to achieve. I want
>> to draw rectangles(strict horizontally aligned) and after drawing
>> it might require a little bit of modification but again it
>> shouldn't lose its shape.
>> Here is what I tried doing:
>> polygonLayer = new OpenLayers.Layer.Vector("Capture Region",
>> {displayInLayerSwitcher: true, reproject: true});
>> polyOptions = {sides: 4, snapAngle: 180, irregular:
>> true}; //To draw only rectangles
>> var pan = new OpenLayers.Control.Navigation({title:
>> "Navigate"})
>> polygonControl = new
>> OpenLayers.Control.DrawFeature(polygonLayer,
>> OpenLayers.Handler.RegularPolygon,
>> {handlerOptions: polyOptions});
>> modify = new OpenLayers.Control.ModifyFeature(
>> polygonLayer, {displayClass:
>> "olControlModifyFeature", title: "Modify Features"},
>> {mode: ~OpenLayers.Control.ModifyFeature.RESHAPE
>> | OpenLayers.Control.ModifyFeature.RESIZE
>> | OpenLayers.Control.ModifyFeature.DRAG }
>> var panel = new OpenLayers.Control.Panel({
>> displayClass: "olControlEditingToolbar"
>> panel.addControls([pan, polygonControl, modify]);
>> map.addControl(panel);
>> The problem is it doesn't follow the modify feature modes I have
>> defined. It allows reshaping and doesn't allow dragging and
>> resizing. Another problem I have is when I define the
>> displayClass for draw feature, it wouldn't let me draw rectangles
>> that are horizontally aligned. To point your attention towards
>> where I might be making a mistake, I am using
>> OpenLayers.Handler.RegularPolygon to draw feature. Is that a problem?
>> Thanks a lot for taking time to read my problem and I'd really
>> appreciate if you could help me with any suggestions and ideas.
>> Thanks!
>> Moiz
>> Dev mailing list
>> Dev at lists.osgeo.org <mailto:Dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
> Dev mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100916/87b1815a/attachment-0001.html
More information about the Dev
