[OpenLayers-Dev] root.parentNode is null for svg renderer
DiCiaccio, Ray - 0442 - MITLL
ray.diciaccio at ll.mit.edu
Wed Sep 22 16:43:20 EDT 2010
Hi list,
I've made some extensive modifications/additions to the OpenLayers library to support our development here, but now I'm running into some issues with the SVG renderers. The problem seems to have something to do with the root node of a renderer becoming detached from the DOM, so that when
OpenLayers.Renderer.Elements.moveRoot() is called, it fails on:
root.parentNode.removeChild(root);
because root.parentNode is null.
I'm not manually removing this node at any point in my code, and I'm having a really difficult time tracking down where this occurs. Does anyone have any clues as to why this node might be removed or just even where in the OpenLayers library such a call might happen?
Thanks
- Ray
More information about the Dev
