[OpenLayers-Dev] GML 3.2.1, <Ring> and <LineStringSegment>
Steven Ottens
steven at minst.net
Fri Sep 24 07:38:26 EDT 2010
Hi all,
I've got a GML 3.2.1 response which uses:
<MultiSurface><surfaceMember><Surface><patches><PolygonPatch><exterior>
<Ring><curveMember><Curve><segments><LineStringSegment><posList>
Which unfortunately is a valid in an insane GML kind of way. The trouble I have is that OpenLayers parses the posList as a OpenLayers.Geometry.LineString, since it is a LineStringSegment. However the Polygon geometry expects a OpenLayers.Geometry.LinearRing.
I've added a "Ring" reader to Format.GML.v3:
"Ring": function(node, obj) {
var container = {};
this.readChildNodes(node, container);
obj.components = [new OpenLayers.Geometry.LinearRing(
container.points
But the container which is passed on from the LineStringSegment reader does not contain points anymore, but a LineString component.
Is there a way to get the points out of this LineString component? Or does anyone have an alternative approach?
regards,
Steven
More information about the Dev
