[OpenLayers-Dev] GML 3.2.1, <Ring> and <LineStringSegment>
Steven Ottens steven at minst.net
Fri Sep 24 07:52:16 EDT 2010
Hi Bart,
Thanks, I didn't think it would be so easy ;)
"Ring": function(node, obj) {
                var container = {};
                this.readChildNodes(node, container);
                obj.components = [new OpenLayers.Geometry.LinearRing(
                    container.components[0].getVertices()
does the trick
On Sep 24, 2010, at 1:44 PM, Bart van den Eijnden (OSGIS) wrote:
> Hi Steven,
> how about getVertices?
> Best regards,
> Bart
>> Hi all,
>> I've got a GML 3.2.1 response which uses:
>> <MultiSurface><surfaceMember><Surface><patches><PolygonPatch><exterior>
>> <Ring><curveMember><Curve><segments><LineStringSegment><posList>
>> Which unfortunately is a valid in an insane GML kind of way.  The trouble
>> I have is that OpenLayers parses the posList as a
>> OpenLayers.Geometry.LineString, since it is a LineStringSegment. However
>> the Polygon geometry expects a OpenLayers.Geometry.LinearRing.
>> I've added a "Ring" reader to Format.GML.v3:
>>                var container = {};
>>                    container.points
>> But the container which is passed on from the LineStringSegment reader
>> does not contain points anymore, but a LineString component.
>> Is there a way to get the points out of this LineString component? Or does
>> anyone have an alternative approach?
>> regards,
>> Steven
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
