[OpenLayers-Dev] hello sample trouble
Andreas Hocevar
ahocevar at opengeo.org
Thu Sep 30 05:31:04 EDT 2010
thanks for letting us know. I just updated the MultiMap API key for that example, and in a few hours you should be able to see the example using this url:
http://openlayers.org/dev/examples/mm.html
Regards,
Andreas.
On Sep 30, 2010, at 08:53 , Tonton wrote:
> hello i just found error on this url
> http://dev.openlayers.org/releases/OpenLayers-2.10/examples/mm.html
> about multi map not correctly load ..
> regards
> tonton
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
