[OpenLayers-Dev] Harware accelerated CSS3 animations for iOS
Andreas Hocevar
ahocevar at opengeo.org
Wed Apr 13 03:40:17 EDT 2011
On Apr 12, 2011, at 22:44 , Eric Lemoine wrote:
> On a related note I've been trying to apply -webkit-transform
> translate3d to the layer container div for dragging the map. But with
> limited success for now—applying translate3d seems to work but, for
> some reason, the layer container is positioned back to its initial
> position later in the "drag thread".
Maybe because of http://trac.osgeo.org/openlayers/browser/trunk/openlayers/lib/OpenLayers/Map.js#L1699-L1718 where the existing layerContainerDiv position is used to create the next one.
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
