[OpenLayers-Dev] Adding a vector layer to an invisible map
Julien-Samuel Lacroix
jlacroix at mapgears.com
Fri Apr 15 15:51:22 EDT 2011
Hello,
I'm trying to add a vector layer to a map on an undisplayed element. I
get an error in 2.10 and it was working in 2.7.
After looking at the code it seems related to:
http://trac.osgeo.org/openlayers/ticket/2414
It's working with 2.7 and 2.8 and started to fail at 2.9.
I attached a patch that add a test for this. Is this relevant?
I'm not sure what's the right way to fix this. Fix getCurrentSize() or
fix Renderer.js to validate if the size is valid.
Julien
Mapgears
http://www.mapgears.com/
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110415/12f8f597/patch_invisimap.bin
More information about the Dev
