[OpenLayers-Dev] Event when a tile fails to load
Karsten Pihl kpo.carlbro at gmail.com
Wed Apr 20 08:32:43 EDT 2011
When a tile fails to load the OpenLayers.Util.onImageLoadError takes
care of handling the error and the “loadend” event is called without
any indication on if one or more tiles are missing.
Attached patch add support for layer events when a tile has failed
loading. When a single tile is missing it trigger the event
“loadwarning” to indicate that something is wrong with this layer.
When all the tiles in a layer are missing it trigger the event
“loadfail”.
The patch includes an update to the event.html example.
/Karsten
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110420/e3d9e8a2/layerload_event.bin
More information about the Dev mailing list
