[OpenLayers-Dev] 'del' key pressed in ModifyFeature to delete it
Alexandre Dube
adube at mapgears.com
Fri Apr 22 12:42:54 EDT 2011
I modified the patch again to include tests, an example and some
fixes. I put the state back to "review".
http://trac.osgeo.org/openlayers/ticket/3016#comment:10
Kind regards,
Alexandre
On 11-01-31 11:23 AM, Alexandre Dube wrote:
> Hi,
> I uploaded a small patch allowing that new feature [1]. There's
> also a live demo url in the ticket showing the feature in action. I
> put the ticket state to "review". Do I need to do anything else ?
> Regards,
> Alexandre
> [1] http://trac.osgeo.org/openlayers/ticket/3016#comment:2
> On 11-01-18 09:36 AM, Alexandre Dube wrote:
>> Hi,
>> I created a ticket [1] for that new feature. I will be able to
>> work on it in the following weeks.
>> Best regards,
>> Alexandre
>> On 11-01-15 03:39 PM, Eric Lemoine wrote:
>>> On Fri, Jan 14, 2011 at 2:24 PM, Alexandre Dube<adube at mapgears.com>
>>> wrote:
>>>> Hi devs,
>>>> Currently, in the ModifyFeature control, when you hover a vertice
>>>> and press
>>>> the 'del' key, it deletes it. While hovering nothing, nothing
>>>> happens. I'd
>>>> like to propose this change : when hovering nothing, if the 'del'
>>>> key is
>>>> pressed, it deletes the feature ( firing 'beforefeaturedeleted' and
>>>> 'featuredeleted' events in order for users to add any kinds of custom
>>>> warning message before doing so).
>>>> Thoughts ?
>>> It sounds good to me.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
