[OpenLayers-Dev] Re: It is desirable to use Navigation in EditingToolbar?
Xavier Mamano (jorix) xavier.mamano at gmail.com
Fri Apr 29 10:09:17 EDT 2011
I created three tickets related to this matter, one is a bug. Now they are
in 2.12 but some might be desirable to put them in 2.11.
 * Bug, highlight the default control
http://trac.osgeo.org/openlayers/ticket/3268
 * To pan the map and draw in editingtoolbar
http://trac.osgeo.org/openlayers/ticket/3269
 * To pan the map and draw in some examples
http://trac.osgeo.org/openlayers/ticket/3271
Xavier Mamano
Eric Lemoine-2-2 wrote:
> On Wednesday, April 20, 2011, Xavier Mamano (jorix)
> <xavier.mamano at gmail.com> wrote:
>> Hi,
>> After allowing pan while drawing. I think in "EditingToolbar" will be
>> interesting to use a empty control instead of Navigation (as
>> examples/mobile-drawing.html) and have Navigation always active. Or at
>> least give this option.
>> There are also a few examples which mounted a toolbar to draw or
>> navigate, I think it would also be interesting to work on them.
>> In 2.11 or 2.12?
> I personally see the EditingToolbar more as an example of how to
> assemble tools in a panel. So I wouldn't see much value in changing it
> as you're suggesting it, taking into account that that would break
> existing applications' UIs. But I agree we could work on our examples
> and show how to build custom editing toolbars (as done in the
> mobile-drawing example), so patches are very welcome here.
> This is just my viewpoint, and I'm happy to have opinions from others.
> Thanks,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
View this message in context: http://osgeo-org.1803224.n2.nabble.com/It-is-desirable-to-use-Navigation-in-EditingToolbar-tp6290886p6317034.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
