[OpenLayers-Dev] SVG render in IE9
Andreas Hocevar
ahocevar at opengeo.org
Tue Aug 2 06:39:23 EDT 2011
On Aug 2, 2011, at 12:34 , Denis Rykov wrote:
> Thanks, it works! Could you give a little explanation why it occurs?
IE9 only provides reliable SVG support if that doctype is set. It has to do with the fact that IE tries to maintain compatibility with older IE versions, based on the doctype (and other settings in the document's head).
Andreas.
> On Tue, Aug 2, 2011 at 5:25 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> make sure to set the doctype properly in your HTML document:
> <!DOCTYPE html>
> Andreas.
> On Aug 2, 2011, at 12:23 , Denis Rykov wrote:
> > Try to use SVG render with IE9 and get an error: "Your browser does not support vector rendering".
> > OpenLayers breaks on 558 line of addFeatures method in Vector.js file: "this.renderer.locked = true;" - is null or undefined.
> > The way I use for adding layer:
> > var geojson_format = new OpenLayers.Format.GeoJSON();
> > map_vector_layer = new OpenLayers.Layer.Vector("", {styleMap: sm, rendererOptions: {zIndexing: true}});
> > map.addLayer(map_vector_layer);
> > map_vector_layer.addFeatures(geojson_format.read(regions));
> > Dev mailing list
> > Dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
Andreas Hocevar
More information about the Dev
