[OpenLayers-Dev] Re: Apply sld_body in a layer SQL View of Geoserver ?
Matt Priour mpriour at kestrelcomputer.com
Fri Aug 5 22:04:19 EDT 2011
I would actually ask this on the Geoserver list.
Also, try it in cURL, REST Console, or Fiddler. If you can mess with the
parameters a bit and get it to work, then you know you can force OL to do
the same.
If it won't work in that pure request/response environment then it is not
going to work in OL and the problem is likely a geoserver issue.
Personally, I would search / ask on the geoserver users list first, if
geoserver should support that use case. If not, or if it is a known issue,
then you can stop trying to get it to work in OL.
Matt Priour
Kestrel Computer Consulting
Matt Priour
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Apply-sld-body-in-a-layer-SQL-View-of-Geoserver-tp6656335p6658661.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
