[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior
	changes
    Eric Lemoine
    eric.lemoine at camptocamp.com
    Sat Aug  6 18:01:49 EDT 2011
On Sat, Aug 6, 2011 at 9:32 PM, RICHARD Didier <didier.richard at ign.fr> wrote:
>>>>>> 2/ in test 4, if you remove the initialize function from B and
>>>>>> overload
>>>>>> A,
>>>>>> the B constructor is still the previous A's constructor.
>>>>> Yes. To address this one I see no other solution than patching
>>>>> OpenLayers.Class. See the patch attached to this email, and my
>>>>> test_overload_5 test function. The Class.html tests continue to pass
>>>>> with my patch.
>>>> this works in OL 2.11, not in OL 2.10 for me !-(
>>>> I guess there is something similar to do in OL 2.10 ?
>>> Your initial mail was about OpenLayers trunk/2.11 introducing
>>> regressions. Now the failing test that remains is OL 2.10-only, so OL
>>> trunk/2.11 works better than OL 2.10 for you. Yippee! :-)
>> My initial mail was really about regression between 2.10 and 2.11 !-)
>>> (Not sure it is worth "fixing" OL 2.10 for that.)
>> Well, one of my test is versus the current release (2.10) and I am sure
>> there are users that will migrate slower than us (I mean OL and IGNF) ...
>> I do think it is worth fixing it ... at least to prove there is no
>> regression !-D
> I've got somethinf working, hence ugly :-)
>    OpenLayers.overload= function(P,F) {
>        var pProtoInitialize= typeof(F.initialize)=="function"?
>            P.prototype.initialize
>        :   null;
>        OpenLayers.Util.extend(P.prototype, F);
>        if (pProtoInitialize!==null) {
>            // override sub-class having same constructor:
>            for (var pn in P) {
>                if (typeof(P[pn])=='function' &&
> P[pn].prototype.initialize===pProtoInitialize) {
>                    var f= {};
>                    eval('f= {"initialize":'+F.initialize.toString()+'}');
>                    P[pn]= OpenLayers.overload(P[pn],f);
>        return P;
Hi Didier. Just to say that I personally wouldn't rely on an overload
function that assumes subclasses use their parent constructors as
their namespaces.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
