[OpenLayers-Dev] 2.10 and 2.11-RC1 OpenLayers.Class behavior
changes
RICHARD Didier
didier.richard at ign.fr
Sun Aug 7 08:10:26 EDT 2011
> On Sat, Aug 6, 2011 at 9:32 PM, RICHARD Didier <didier.richard at ign.fr>
> wrote:
>>>>>>> 2/ in test 4, if you remove the initialize function from B and
>>>>>>> overload
>>>>>>> A,
>>>>>>> the B constructor is still the previous A's constructor.
>>>>>> Yes. To address this one I see no other solution than patching
>>>>>> OpenLayers.Class. See the patch attached to this email, and my
>>>>>> test_overload_5 test function. The Class.html tests continue to pass
>>>>>> with my patch.
>>>>> this works in OL 2.11, not in OL 2.10 for me !-(
>>>>> I guess there is something similar to do in OL 2.10 ?
>>>> Your initial mail was about OpenLayers trunk/2.11 introducing
>>>> regressions. Now the failing test that remains is OL 2.10-only, so OL
>>>> trunk/2.11 works better than OL 2.10 for you. Yippee! :-)
>>> My initial mail was really about regression between 2.10 and 2.11 !-)
>>>> (Not sure it is worth "fixing" OL 2.10 for that.)
>>> Well, one of my test is versus the current release (2.10) and I am sure
>>> there are users that will migrate slower than us (I mean OL and IGNF)
>>> I do think it is worth fixing it ... at least to prove there is no
>>> regression !-D
>> I've got somethinf working, hence ugly :-)
>> OpenLayers.overload= function(P,F) {
>> var pProtoInitialize= typeof(F.initialize)=="function"?
>> P.prototype.initialize
>> : null;
>> OpenLayers.Util.extend(P.prototype, F);
>> if (pProtoInitialize!==null) {
>> // override sub-class having same constructor:
>> for (var pn in P) {
>> if (typeof(P[pn])=='function' &&
>> P[pn].prototype.initialize===pProtoInitialize) {
>> var f= {};
>> eval('f=
>> {"initialize":'+F.initialize.toString()+'}');
>> P[pn]= OpenLayers.overload(P[pn],f);
>> return P;
> Hi Didier. Just to say that I personally wouldn't rely on an overload
> function that assumes subclasses use their parent constructors as
> their namespaces.
Hi Eric,
The key issue here is just to progagate the constructor's change to
sub-classes. One can imagine a third parameter (propagate - {Boolean}) to
the overload method (or an {Object} holding options like propagate), but
in that case, the behavior of 2.10/2.11 are not aligned when applying your
patch (on the other hand, without your patch no way to propagate the
changes to sub-classes constructors !) ...
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
RICHARD Didier - Chef du pôle technique du Géoportail
2/4, avenue Pasteur - 94165 Saint Mandé Cedex
Tél : +33 (0) 1 43 98 83 23
More information about the Dev
