[OpenLayers-Dev] Problem using WMS Post + sld_body +
singleTile:true
Andreas Hocevar
ahocevar at opengeo.org
Mon Aug 8 04:45:20 EDT 2011
please scratch my previous comment. The issue you are describing was fixed with http://trac.osgeo.org/openlayers/changeset/12116. So if you use the latest trunk version of OpenLayers, you should see the issue gone. Or you can apply http://trac.osgeo.org/openlayers/attachment/ticket/3376/IFrame.js.patch to 2.11-rc1.
Andreas.
On Aug 8, 2011, at 10:40 , Andreas Hocevar wrote:
> Hi,
> are you working with OpenLayers 2.11-rc1 or trunk? If so, can you please apply the patch attached to http://trac.osgeo.openlayers.org/ticket/3419 and see if this resolves your issue?
> Thanks,
> Andreas.
> On Aug 8, 2011, at 01:49 , Davi Custódio wrote:
>> Hello all,
>> My problem is relation to a use of a layer WMS Post with the singleTite:
>> true, that makes a layer that is using sld_body, behaves strangely ... I
>> have tried several alternatives. Using wms.post after using tileOptions:
>> maxGetUrlLength {2048}, but the problem persists. Interestingly, for the
>> layers that have sld_body, who are using singleTile: false, do a Zoom or
>> Pan, and possibly randomly OpenLayers does not clear the cache and leaves a
>> trail that is not quenched. Now for the layers that use singleTile: true, a
>> strange thing happens in the transition effect, repainting the tiles before
>> setting up completely before the new tiles (or after a zoom or pan). For a
>> layer that uses singleTile: true, using Chrome, it works OK. But for the
>> IEs, Firefox and Safari, the problem of transition strange happens. I also
>> tried using transitionEffect: 'default' and did not work. Do you think there
>> is still no solution to this bug related to layers containing sld_body and
>> use singleTile: true? Thank you.
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-using-WMS-Post-sld-body-singleTile-true-tp6662685p6662685.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Dev mailing list
Andreas Hocevar
More information about the Dev
