[OpenLayers-Dev] Re: trace along feature
Gagan Bansal gaganbansal123 at gmail.com
Tue Aug 9 03:01:27 EDT 2011
I have fixed the bug and I'll make patch for openlayers.
There is one issue remaining that I think should be part of trace control.
Like while tracing along polygon the current trace-control trace only in the
direction of the ring of polygon. Another input from user need to be taken
like if shift pressed  to trace  in reverse direction. I need to go through
how to handle event.shiftKey.
Regards,
Gagan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/trace-along-feature-tp6655335p6667126.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
