[OpenLayers-Dev] method for initializing a Openlayers interface witha centerpoint and view scale.
Peter Körner osm-lists at mazdermind.de
Thu Aug 25 04:07:48 EDT 2011
Hi
sometimes some lines of code says more then a hundred words :)
Tak a look at http://toolserver.org/~osm/styles/ and see, if it helps
you. It uses the default permalink format:
<http://toolserver.org/~osm/styles/?zoom=12&lat=50.11485&lon=8.66684>
Peter
Am 23.08.2011 21:57, schrieb Bob Basques:
> All,
> Does a mechanism for the subject exist?
> I want to initialize a Openlayers map with a centerpoint and a scale of
> view (and passing in layer names to turn on/off would be a plus as well,
> but not required, yet)
> Doing a tabular address lookup, and want to add in a zoom-to link for
> each of the results.
> Thanks
> bobb
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
