[OpenLayers-Dev] Re: Adding Segment Length to Path
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Fri Dec 9 19:38:20 EST 2011
Hi Yus,
Sorry, is not a good idea to take the same layer of the handler. Forget it!
Now callbacks no longer serve in the same way, I think it is better to use
"point" instead of "modify". And `destroyFeatures` in the first "point"
(`this.mouseMovements == 0`) , and in "create" only set `this.mouseMovements
= 0`.
The freehand is another problem, it is dirty.
I'll try step by step and answer tomorrow.
Xavier
Xavier Mamano (jorix) wrote
> Hi Yus,
> Interesting...
> You will need to assign value to the `vlayer` in callbacks `create` and
> `modify` as:
> var vlayer = this.handler.layer;
> that's it!
> Xavier
> Yus wrote
>> Hi.
>> Ran into a small problem when change to OpenLayers 2.11 with showing the
>> length of each segment on the measuring line.
>> Previously after placing points A --> B, B --> C. The length of segment A
>> to B would show up between those points, likewise with B to C and after
>> ending the line the total would be displayed.
>> My script worked fine with OpenLayers 2.10, but after changing to
>> OpenLayers 2.11 as soon as I end the line only the segment values
>> disappear from the vector layer.
>> I understand the problem, but am having trouble working out the logic...
>> Below is the script I am using:
>> line: new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {
>> persist: true,
>> handlerOptions: {
>> layerOptions: {
>> renderers: renderer,
>> styleMap: styleMap
>> textNodes: null,
>> callbacks:{
>> create:
>> function(){
>> this.textNodes = [];
>> vlayer.destroyFeatures(vlayer.features); *<-- Believe the
>> problem is here*
>> mouseMovements = 0;
>> modify:
>> function(point, line){
>> if(mouseMovements++ < 5){
>> return;
>> var len = line.geometry.components.length;
>> var from = line.geometry.components[len -2];
>> var to = line.geometry.components[len -1];
>> var ls = new OpenLayers.Geometry.LineString([from, to]);
>> var dist = this.getBestLength(ls);
>> if(!dist[0]){
>> return;
>> var total = this.getBestLength(line.geometry);
>> var label = dist[0].toFixed(3) + " " + dist[1];
>> var textNode = this.textNodes[len -2] || null;
>> if(textNode && !textNode.layer){
>> this.textNodes.pop();
>> textNode = null;
>> if(!textNode){
>> var c = ls.getCentroid();
>> textNode = new OpenLayers.Feature.Vector(
>> new OpenLayers.Geometry.Point(c.x, c.y), {}, {
>> label: "",
>> fontColor: "#800517",
>> fontSize: "12px",
>> fontFamily: "Tahoma",
>> fontWeight: "bold",
>> labelAlign: "cm"
>> this.textNodes.push(textNode);
>> vlayer.addFeatures([textNode]);
>> textNode.geometry.x = (from.x + to.x) / 2;
>> textNode.geometry.y = (from.y + to.y) / 2;
>> textNode.style.label = label;
>> textNode.layer.drawFeature(textNode);
>> this.events.triggerEvent("measuredynamic", {
>> measure: dist[0],
>> total: total[0],
>> units: dist[1],
>> order: 1,
>> geometry: ls
>> Any advice is very appreciated. Thanks in advance
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-Segment-Length-to-Path-tp7029815p7080319.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
