[OpenLayers-Dev] Class.inherit
Eric Lemoine
eric.lemoine at camptocamp.com
Sat Feb 12 06:12:45 EST 2011
On Friday, February 11, 2011, Slawomir Messner
<slawomir.messner at staff.uni-marburg.de> wrote:
> Hi,
> I updated our version of OpenLayers to svn trunk. Now I get the following error:
> P is undefined
> I debugged a lot and there seems to be a problem with classes which inherit from a class which is not directly inherits form Class, like ZoomPanel where this error occurs first. Then I tried to fix it with adding OpenLayers.Control as first inherit class:
> OpenLayers.Control.ZoomPanel = OpenLayers.Class(OpenLayers.Control,OpenLayers.Control.Panel,...
> this works but then the next class came where the parent class is not Control or Class it self. So I edited all of them (I was not expect that this is the solution but I was interested what next comes). The next thing was that the Navigation control couldn't initialize the DragPan. OL.Control.DragPan was undefined.
> This was the point where I rollback the changes till the update and tried it with several older versions of Class, OpenLayers.js but nothing helped, the error was OpenLayers is undefined.
> In hope someone can help me so I don't have to rollback before the update and we can stay compatible with the new trunk.
Hi. Could you please provide a small example (with actual code)
demonstrating the problem? We haven't seen any problem with the new
Class impl. until now.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
