[OpenLayers-Dev] WFS-T and fid property
Alexandre Dube
adube at mapgears.com
Mon Feb 14 11:26:37 EST 2011
Using Firebug, put a break point in the onCommit method of the Save
strategy to see what's going on. That could give you a hint. Also,
have you tried with different versions of OpenLayers (2.10, trunk) ?
Best regards,
Alexandre
On 11-02-14 11:18 AM, Denis Rykov wrote:
> Hi!
> I'm not sure this right place for my message, but Ive discovered the
> following problem.
> I'm using Openlayers and WFS-T Server - TinyOWS. When I add new
> features to layer and commit changes - I get answer from TinyOWS, for
> example:
> <?xml version='1.0' encoding='utf-8'?>
> <wfs:WFS_TransactionResponse version="1.0.0"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ogc="http://www.opengis.net/ogc"
> xsi:schemaLocation='http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd'>
> <wfs:InsertResult handle="TinyOWS-WFS-default-handle"><ogc:FeatureId
> fid="views.157"/><ogc:FeatureId fid="views.158"/><ogc:FeatureId
> fid="views.159"/></wfs:InsertResult>
> <wfs:TransactionResult>
> <wfs:Status><wfs:SUCCESS/></wfs:Status>
> </wfs:TransactionResult>
> </wfs:WFS_TransactionResponse>
> But only one (the first) of newly created feature of layer in
> OpenLayers contains fid property, another feature have fid value =
> null. Is this problem of OpenLayer or TinyOWS. Could anyone confirm
> described behavior? Now I'm using refresh() method of layer, but I
> guess this is not best way.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
