[OpenLayers-Dev] Mobile examples using mobile build
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Fri Feb 25 14:14:15 EST 2011
As of r11538, the mobile examples use a mobile-specific build on the
main website. If you create a mobile example which works with the
mobile.cfg build, you can add ?mobile to the OpenLayers.js path in
the examples and that example will use a singleFile mobile build
on the live examples.
-- Chris
More information about the Dev mailing list
