[OpenLayers-Dev] SRS id in BBOX parameter
Tim Schaub
tschaub at opengeo.org
Wed Jan 5 14:42:52 EST 2011
Hey-
Are there people that use the HTTP protocol against services that would
break if the BBOX query string parameter included the SRS identifier?
E.g.
http://example.com/features?bbox=1,2,3,4,foo
The WFS 1.1 spec allows clients to specify the SRS for a bounding box by
including the SRS identifier as the fifth item in the array. I'd like
to add this functionality to the HTTP protocol if it wouldn't make
existing applications break.
http://trac.osgeo.org/openlayers/ticket/3006
An alternative would be to only invoke this functionality if a property
were set on the protocol.
Thanks for any feedback,
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
