[OpenLayers-Dev] SRS id in BBOX parameter
Tim Schaub tschaub at opengeo.org
Wed Jan 5 16:17:19 EST 2011
Thanks for the replies.
I've updated the patch to introduce a srsInBBOX property.
http://trac.osgeo.org/openlayers/ticket/3006
Tim
On 1/5/11 1:02 PM, Eric Lemoine wrote:
> On Wed, Jan 5, 2011 at 8:57 PM,<christopher.schmidt at nokia.com>  wrote:
>> On Jan 5, 2011, at 2:42 PM, ext Tim Schaub wrote:
>>> Hey-
>>> Are there people that use the HTTP protocol against services that would break if the BBOX query string parameter included the SRS identifier?
>>> E.g.
>>> http://example.com/features?bbox=1,2,3,4,foo
>>> The WFS 1.1 spec allows clients to specify the SRS for a bounding box by including the SRS identifier as the fifth item in the array.  I'd like to add this functionality to the HTTP protocol if it wouldn't make existing applications break.
>> FeatureServer would break; "action.bbox = map(float, value.split(","))" would barf on
>> it if the value were not a float-able number, I believe.
> Same for MapFish.
>>>> bbox = map(float, "1,2,3,4,foo".split(","))
> Traceback (most recent call last):
>    File "<stdin>", line 1, in<module>
> ValueError: invalid literal for float(): foo
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
