[OpenLayers-Dev] "allow pan while drawing" patch
Eric Lemoine
eric.lemoine at camptocamp.com
Wed Jan 12 08:54:30 EST 2011
On Wed, Jan 12, 2011 at 2:41 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Hi Eric,
> I really like the idea of being able to pan while drawing features. I
> tried yours examples and here's my comments about them.
> === about your patch ===
> Drawing a new point on mouseup seemed odd on first impression, but I could
> live with it. Then, I noticed some down effects. When trying do quickly
> draw a line, it kept missing some points along the way.
This is probably because you start moving the mouse before mouseup. We
could possibly introduce a tolerance for that.
> I'm not sure if
> that could be an issue since when you draw (normally), you take your time.
> Your new feature seems "mobile compatible" though, and that's a plus.
> === an other idea ===
> The first time I used the draw feature control, I noticed that I couldn't
> pan the map with the mouse. The first thing I tried to do is move the mouse
> out of the map. I thought the map would follow by panning itself.
Personally I think that be able to pan while drawing is good enough,
but we could indeed add fancier stuff eventually.
Thanks a lot for your feedback.
PS: Yves Jacolin just told me that it actually also works for "draw
polygon", that's very good to know :-)
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
