[OpenLayers-Dev] "allow pan while drawing" patch
Tim Schaub
tschaub at opengeo.org
Thu Jan 13 14:30:15 EST 2011
I should add. I'll be interested to hear what you think about
supporting freehand and snapping together. This is a combination of
functionality that we're relying on.
I haven't dug around your changes yet. I'll be interested to do that
whenever time allows.
Tim
On 1/13/11 7:26 AM, Eric Lemoine wrote:
> On Wed, Jan 12, 2011 at 1:22 PM, Andreas Hocevar<ahocevar at opengeo.org> wrote:
>> Hi Eric,
>> thanks for your efforts. My only concern is that adding vertices on mouseup instead of mousedown negatively affects the user experience when a Snapping control is used. This is because the user doesn't see any more where the vertex is going to be snapped to.
>> At this point, I have no idea how to solve this.
> Thanks for explaining.
> Some of us here at Camptocamp have discussed this a bit further, and
> we've come up with a potential solution to this issue, where the first
> point to be laid down is drawn as the soon as the control is active
> (or the previous feature is finalized).
> See the demo on
> <http://dev.openlayers.org/sandbox/elemoine/draw-feature/examples/snapping.html>.
> You should have a point following the mouse as soon as the draw tool
> is made active in the toolbar.
> Cheers,
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
