[OpenLayers-Dev] Bing "mapVersion" Patch
Andreas Hocevar ahocevar at opengeo.org
Fri Jan 14 07:15:24 EST 2011
Hi Jeff,
thanks a lot for your contribution! The usual process is to create a ticket on http://trac.osgeo.org/openlayers/ and attach the patch there. Patches should also have unit tests.
This time I have created the ticket for you and attached the patch: http://trac.osgeo.org/openlayers/ticket/3013
Let's do the follow-up discussion on that ticket.
Andreas.
On Jan 14, 2011, at 02:40 , Jeff Maki wrote:
> Hello OpenLayers Developers!
> It's my first time submitting a patch to OpenLayers, so my apologies in advance if I'm going about it in the wrong way...
> I recently needed to control which imagery set was used on my Bing map, using the new REST-ful Bing tile access API and the related OpenLayers layer type. I didn't see a way to pass in the proper parameters to the "get metadata" call Bing uses, and so I modified OpenLayers appropriately and generated the attached patch against trunk.
> In short, if you set the new param to "v1", you can use the same tileset Bing is using on their website now (which they say will become the default if you don't specify a tile version sometime in the future).
> Hoping somebody can review this and commit it to trunk for me?
> Thanks--feedback welcomed, of course.
> -Jeff
> Jeff Maki
> Project Lead
> OpenPlans
> 917-388-9088
> jmaki at openplans.org
> <BingMapVersionPatch.patch>_______________________________________________
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
