[OpenLayers-Dev] 'del' key pressed in ModifyFeature to delete it
Alexandre Dube
adube at mapgears.com
Tue Jan 18 09:36:43 EST 2011
I created a ticket [1] for that new feature. I will be able to work
on it in the following weeks.
Best regards,
Alexandre
[1] http://trac.osgeo.org/openlayers/ticket/3016
On 11-01-15 03:39 PM, Eric Lemoine wrote:
> On Fri, Jan 14, 2011 at 2:24 PM, Alexandre Dube<adube at mapgears.com> wrote:
>> Hi devs,
>> Currently, in the ModifyFeature control, when you hover a vertice and press
>> the 'del' key, it deletes it. While hovering nothing, nothing happens. I'd
>> like to propose this change : when hovering nothing, if the 'del' key is
>> pressed, it deletes the feature ( firing 'beforefeaturedeleted' and
>> 'featuredeleted' events in order for users to add any kinds of custom
>> warning message before doing so).
>> Thoughts ?
> It sounds good to me.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
