[OpenLayers-Dev] saving a vector file permanently
Mohammed Rashad mohammedrashadkm at gmail.com
Fri Jan 21 09:24:28 EST 2011
thanks David,
I mean something like you said. Also please tell me how can I edit and save
attributes too
On Fri, Jan 21, 2011 at 7:47 PM, David Zwarg
<dzwarg+ol at azavea.com<dzwarg%2Bol at azavea.com>
> wrote:
> Hello Mohammed,
> Look at the OpenLayers.Format classes.
> Here's a link to the geojson format example:
> http://dev.openlayers.org/apidocs/files/OpenLayers/Format/GeoJSON-js.html
> You will probably do something like:
> var format = new OpenLayers.Format.GeoJSON();
> // given that 'layer' is a vector layer attached to the map with some
> features:
> var jsonstring = format.write( layer.features );
> // given that 'txtarea' is an HTML textarea element somewhere in your page
> to display the geojson:
> txtarea.value = jsonstring;
> There's no way to save the file directly via openlayers (opening a "Save
> File..." dialog), you have to do some copy & pasting from the browser.
> -z
> On Fri, Jan 21, 2011 at 8:51 AM, Mohammed Rashad <
> mohammedrashadkm at gmail.com> wrote:
>> How can I save a OpenLayers.Layer.Vector to a gml, geojson or any
>> openlayer supported formats without using
>>  WFS or WFS- T( without geoserver,postgis);
>> Is it possible?
>> Rashad
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Rashad
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110121/db676c76/attachment.html
More information about the Dev mailing list
