[OpenLayers-Dev] mobile-jq example does not work with current jQuery Mobile (was: Current and Future jQuery mobile will not work with OpenLayers.)
Noli Sicad nsicad at gmail.com
Tue Jul 12 06:05:33 EDT 2011
I got this same error (below)  in my 2 other jquery mobile projects
aside from the mobile-jq example from OpenLayers.
OpenLayers.js:1234TypeError: Result of expression 'size' [null] is not
an object.
This is line 1234 (below)
var schema={};this.readNode(data,schema);return
schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return
false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return
this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
Noli
On 7/12/11, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> It also doesn't mean that jQuery is broken. It only means that the
> example does not work with later versions of jQuery than the one used
> in the example.
> Andreas.
> On Tue, Jul 12, 2011 at 11:35 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Andreas,
>> It is not OpenLayers that is broken for sure.
>> It is jQuery mobile that is broken.
>> I like to see another OpenLayers and jQuery mobile project that is
>> working.
>> Noli
>>> Hi Noli,
>>> the subject of this thread adds a lot of drama to to the content that
>>> is not actually there. So I changed the subject. Anybody is welcome to
>>> fix the mobile-jq example. A non-working example does not mean that
>>> OpenLayers is broken.
>>> Regards,
>>> Andreas.
>>> On Tue, Jul 12, 2011 at 10:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>> Hi Andreas,
>>>> I just tested the official jQuery Mobile example in OL 2.11 RC1.
>>>> It is not working with the beta1 jQM release.
>>>> You can download.
>>>> 1.I am using mobile-jq.html in OpenLayers-2.11-rc1.tar.gz
>>>> http://www.openlayers.org/download/
>>>> 2. jQuery Mobile --- Zip File: jquery-mobile-1.0b1.zip (JavaScript,
>>>> CSS, and images)
>>>> http://jquerymobile.com/download/
>>>> 3. jQuery 1.6.2
>>>> http://docs.jquery.com/Downloading_jQuery
>>>> The jquery mobile 1.0b1pre is working after this version. It is not
>>>> working.
>>>> Noli
>>>>> Can we have a link to an example that shows the issue, which uses
>>>>> unminified versions of both OpenLayers and jQuery? This will make it
>>>>> easier to locate the issue.
>>>>> Thanks,
>>>>> Andreas.
>>>>> On Mon, Jul 11, 2011 at 5:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I like to inform everybody that the current and future releases of
>>>>>> jQuery Mobile will not work with OL until this issue is resolved.
>>>>>> https://github.com/jquery/jquery-mobile/issues/search?q=OpenLayers
>>>>>> If you know what is causing the problem, please let us.
>>>>>> Noli
>>>>>> _______________________________________________
>>>>>> Dev mailing list
>>>>>> Dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>> Andreas Hocevar
>>>>> OpenGeo - http://opengeo.org/
>>>>> Expert service straight from the developers.
>>>> Dev mailing list
>>> Andreas Hocevar
>> Dev mailing list
> Andreas Hocevar
More information about the Dev mailing list
