[OpenLayers-Dev] mobile-jq example does not work with current
jQuery Mobile (was: Current and Future jQuery mobile will not work with
OpenLayers.)
Noli Sicad
nsicad at gmail.com
Tue Jul 12 06:21:46 EDT 2011
Is this not the size?
#mappage, #mappage .ui-content, #map {
width: 100%;
height: 100%;
So, where will we put this size / "style" ?
style="width:100%;height:100%;"
Noli
On 7/12/11, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> On Tue, Jul 12, 2011 at 12:05 PM, Noli Sicad <nsicad at gmail.com> wrote:
>> I got this same error (below) in my 2 other jquery mobile projects
>> aside from the mobile-jq example from OpenLayers.
> This only means that the map container does not have a size, probably
> because it is a sub-element of a jqmobile page. Adding a
> attribute to the map div may help.
> Andreas.
>> OpenLayers.js:1234TypeError: Result of expression 'size' [null] is not
>> an object.
>> This is line 1234 (below)
>> var schema={};this.readNode(data,schema);return
>> schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);OpenLayers.Util.extend(this,options);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return
>> false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return
>> this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
>> Noli
>>> It also doesn't mean that jQuery is broken. It only means that the
>>> example does not work with later versions of jQuery than the one used
>>> in the example.
>>> Andreas.
>>> On Tue, Jul 12, 2011 at 11:35 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>> Hi Andreas,
>>>> It is not OpenLayers that is broken for sure.
>>>> It is jQuery mobile that is broken.
>>>> I like to see another OpenLayers and jQuery mobile project that is
>>>> working.
>>>> Noli
>>>>> Hi Noli,
>>>>> the subject of this thread adds a lot of drama to to the content that
>>>>> is not actually there. So I changed the subject. Anybody is welcome to
>>>>> fix the mobile-jq example. A non-working example does not mean that
>>>>> OpenLayers is broken.
>>>>> Regards,
>>>>> Andreas.
>>>>> On Tue, Jul 12, 2011 at 10:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>> Hi Andreas,
>>>>>> I just tested the official jQuery Mobile example in OL 2.11 RC1.
>>>>>> It is not working with the beta1 jQM release.
>>>>>> You can download.
>>>>>> 1.I am using mobile-jq.html in OpenLayers-2.11-rc1.tar.gz
>>>>>> http://www.openlayers.org/download/
>>>>>> 2. jQuery Mobile --- Zip File: jquery-mobile-1.0b1.zip (JavaScript,
>>>>>> CSS, and images)
>>>>>> http://jquerymobile.com/download/
>>>>>> 3. jQuery 1.6.2
>>>>>> http://docs.jquery.com/Downloading_jQuery
>>>>>> The jquery mobile 1.0b1pre is working after this version. It is not
>>>>>> working.
>>>>>> Noli
>>>>>>> Can we have a link to an example that shows the issue, which uses
>>>>>>> unminified versions of both OpenLayers and jQuery? This will make it
>>>>>>> easier to locate the issue.
>>>>>>> Thanks,
>>>>>>> Andreas.
>>>>>>> On Mon, Jul 11, 2011 at 5:43 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>>>>>>> Hi,
>>>>>>>> I like to inform everybody that the current and future releases of
>>>>>>>> jQuery Mobile will not work with OL until this issue is resolved.
>>>>>>>> https://github.com/jquery/jquery-mobile/issues/search?q=OpenLayers
>>>>>>>> If you know what is causing the problem, please let us.
>>>>>>>> Noli
>>>>>>>> _______________________________________________
>>>>>>>> Dev mailing list
>>>>>>>> Dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>>>>>> Andreas Hocevar
>>>>>>> OpenGeo - http://opengeo.org/
>>>>>>> Expert service straight from the developers.
>>>>>> Dev mailing list
>>>>> Andreas Hocevar
>>>> Dev mailing list
>>> Andreas Hocevar
>> Dev mailing list
> Andreas Hocevar
More information about the Dev
