[OpenLayers-Dev] OL trunk + MapServer 6.0 + BBOX Strategy -> WFS server error. Invalid or Unsupported FILTER in GetFeature
Andreas Hocevar ahocevar at opengeo.org
Sat Jul 16 13:24:15 EDT 2011
Hey Roald,
what you describe is exactly the new expected behavior. However, if you add
either a featureNS or a geometryName, things should be working again.
Let me know if you still have concerns, or if and where you think this
should be better documented. If the former, do you have a suggestion how we
could better solve this? Because the intention of the change you suffer from
was to make dynamic WFS configuration simpler.
Andreas.
On Jul 16, 2011 2:38 PM, "Roald de Wit" <list at rdewit.net> wrote:
Hey Andreas,
It's true that I don't set the FeatureNS. However, I *do* set the
featureType *and* the featurePrefix in my protocol options, which used to be
sufficient.
If you take the wfs-protocol.html example from trunk and replace featureNS
with: featurePrefix: 'topp', you'll see that the PropertyName disappears
from the WFS request (in the BBOX filter).
Is this expected behaviour, ie: can I not use featurePrefix anymore or is it
a bug?
Thanks, Roald
On 16/07/11 19:59, Andreas Hocevar wrote:
> > Hey Roald,
> > the PropertyName will still always be set, unless you have a poorly
> configured ...
>> >> On Jul 16, 2011 8:25 AM, "Roald de Wit" <list at rdewit.net <mailto:
>> list at rdewit.net>> wrote:
>> >> H...
>> Dev at lists.osgeo.org <mailto:Dev at lists.osgeo.org>
>> >> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Dev mailing list
http://lists.o...
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110716/6542cfed/attachment.html
More information about the Dev mailing list
